Activity Forums Avid Media Composer Adrenaline Conform Please Help
  • Adrenaline Conform Please Help
    Posted by Matt1028 on February 22, 2006 at 3:44 am
    If anyone here has a solution for this I owe you big time.
    Here goes
    37 source tapes HDCAm shot at 23.98
    Digitized offline into Mac Adrenaline Using J-H3.
    J-H3 was set to Non-Drop
    Spent weeks editing show
    Time to up rez into PC Adrenaline HD with DNxHD board
    Sync Issues up the wazoo
    sometimes frames sometimes seconds
    J-H3 set the same way
    Nothing
    Modify source clips in offline room to Drop Frame
    Set J-H3 to Drop Frame
    Batch Digitize
    Sometimes better, sometimes worse
    Short of re editing the show in offline
    how can I get this conform to work properly
    I tried everything
    Modify clips in offline
    same in online
    please help
    Justin Coleman replied 20 years, 6 months ago 3 Members · 3 Replies
  • Michael Phillips
    February 22, 2006 at 11:24 am
    Was the offline done at 30 and the online at 24? If onlining at 24 there is no concept of drop frame… more details needed on frame rates being used when…
  • Matt1028
    February 22, 2006 at 2:28 pm
    Offline done at 30 drop frame
    Online at 1080i 59.97
  • Justin Coleman
    February 25, 2006 at 7:28 pm
    I’ve had just these problems with every adrenaline I’ve used for the last few years, deck types aside the auto conforms are variably out of sync upto 20 frames. Using SDI and AES to capture and conform first 15.1 or dv420 then online at 1.1 or 2.2. 25fps. I don’t know of a post house in london that hasn’t had these issues with adrenaline.
