Activity Forums Avid Media Composer Adrenaline Color Correcting issue
  • Adrenaline Color Correcting issue
    Posted by Dan L. on February 14, 2006 at 8:53 pm
    Speaking of Adrenaline Funkyness
    Having real problem with Adrenaline HD’d color corrector. WOrks fine until you have to render. when you render a color correction effect get wildly different results than the realtime preview, Ranges from slight incorrect brightness, to looking solarized.
    Any suggestions?
    D
    Dan L. replied 20 years, 7 months ago 2 Members · 2 Replies
  • Geraint Pari huws
    February 15, 2006 at 9:23 am
    with a lack of any other answer…at what quality are you rendering?
  • Dan L.
    February 16, 2006 at 5:45 am
    rendering this @ DNxHD175x 23.98fps.
    Looked a little more carefully at it today. Seems like it is having trouble with blacks, and inverting them once they get below a certain threshold. I enabled 10 bit processing and that did not help. Found that if I set the clip lows to 0 and the highs to 255 it seemed to correct the problem, but kinda a pain to need to do that on every clip.
    Best,
    Dan
