Activity Forums Avid Media Composer Adrenaline Capture Problem
  • Adrenaline Capture Problem
    Posted by William909 on December 29, 2005 at 10:18 pm
    When capturing video I get little ‘dots’ of pixels where the image is blurred – particularly if the image is very busy. It happens from any source (BetaSP, DigiBeta, DVCam), any input (Component, SDI, DV) and at all resolutions. Many ‘dots’ appear on very complex images. Any ideas?
    Brett K replied 19 years, 10 months ago 4 Members · 4 Replies
  • Grinner Hester
    December 31, 2005 at 10:58 pm
    your seeing complex images in little dots?
    that pretty heavy, man.
    how are your video levels? You’ll get artifacts with anything over 100ire. Is it on your NTSC monitor/output as well or just the composer window? I always see hooha in the composer window that doesn’t live to tape.
  • William909
    January 3, 2006 at 5:30 pm
    I see the ‘dots’ on bright parts of images (over/around 100IRE) and on complex parts of images (tight lines, lots of color). It does end up on tape. Any ideas?
  • Jason
    January 3, 2006 at 9:28 pm
    i know on my meridien system i get artifiacting when there are cables loose between boards in my slots. also when there are issues with the 3d board. not sure how that translates to the way the adrenaline works but just thought i’d throw in my 2cents.
    good luck,
    j
  • Brett K
    November 21, 2006 at 6:45 pm
    WILLIAM 909. WERE YOU ABLE TO CORRECT THE PIXEL PROBLEM YOU WERE HAVING WITH YOUR ADRENALINE? I AM EXPERIENCING SOMETHING SIMILAR AND IT HAS ME STUMPED.
    ANY SUGGESTIONS ON THIS PROBLEM BE GREATLY APPRECIATED.
    THANKS
