Activity Forums Adobe Premiere Pro Adobe QT32 Server Not Responding
  • Adobe QT32 Server Not Responding
    Posted by Bob Zelin on November 21, 2014 at 9:59 pm
    Hi –
    getting terrible performance in playback of Premiere CC2014 on Mac Pro with 12gig RAM.
    Drives are fast enough. Open up Activity Monitor on the Mac Pro, and when the problem starts, you
    can see in Activity Monitor in bright red – “Adobe QT32 Server Not Responding”. I did a google search on this, and lots of people complain about it on the Adobe forums, with no apparent solution.
    Is anyone aware of this, or has ever seen this ?
    Thanks –
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
    Barry O’brien replied 11 years, 6 months ago 8 Members · 15 Replies
  • 15 Replies
  • Kevin Monahan
    November 22, 2014 at 1:22 am
    Thanks for posting those links, Andy.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Andy Edwards
    November 22, 2014 at 1:53 am
    Your Welcome. Thanks for adding more details. It sure is a intermittent issue at times, so hard to pin it down for QE to solve. If I come across any more fixes in our bays, I’ll post back.
    Andy Edwards
    Denver
  • John Pale
    November 24, 2014 at 2:50 am
    “We had some playback issues with our older AJA Kona cards and upgraded to the latest drivers. It has helped, but still needed extra fine tuning with the help of AJA support call.”
    Care to post what the extra fine tuning suggestions were?
  • Andy Edwards
    November 24, 2014 at 3:33 pm
    Couple setting changes. This was on our iO4K and also tried with our older Kona 3 card.
    Under Premiere Audio Hardware tab: Change Buffer size to 512.
    Under Premiere Playback tab: AJA Setup: Change video format to Match Sequence, and buffer mode set to Minimum.
    Under AJA Control Panel: Audio set to +12dbu FSD, Format – pixel format set to YUV-8.
    The audio setup change in the AJA Control Panel was specific for our 5.1 concert. It might not effect you if you are dealing with just a stereo mix. We were getting over modulated audio and changing this setting for 5.1 seems to fix that and make the output sound better on our 5.1 speakers.
    Andy Edwards
  • Philip Owens
    February 5, 2015 at 3:06 am
    I’ve just switched to Yosemite and Premiere Pro and am seeing exactly this issue. A simple 2V/6A timeline with all source material ProRes 4444 that would give no problems playing back from my GRAID in FCP 7 is just horrible in PP – playback is terribly stuttering and lots needs to be rendered. I’ve tried the suggestions here to no effect.
  • Tim Ward
    March 14, 2015 at 11:59 pm
    I had this too. Removed all codecs except ProRes from /Library/QuickTime and it helped. No more “Adobe QT32 Server Not Responding.” Now to isolate which specific codec(s).
    Mac Pro 3,1
    24GB
    Premiere Pro 8.2/CC 2014.2
  • Barry O’brien
    March 17, 2015 at 2:20 am
    Thanks to all of you for helping here. I have a similar, possibly related, situation:
    First of all, I have a MacPro 3,1
    2 X 2.8 Quad-Core Intel
    OS Mavericks 10.9.5
    22 Gbs RAM
    I’m using a MacVidCards “flashed” GTX 770 4 Gb for the monitors and
    an AJA Kona LHE+ for the broadcast monitor.
    The sequence, which is just one music track and three checkerboarded video tracks plays back choppy and eventually, Premiere will freeze – you can’t play the sequence, you can’t save, you can’t force quit Premiere. I just have to crash the computer and bring up Premiere again.
    Now, just before this, I had installed a Apple Security Update with a build number 13F1066. MacVidCards pointed me to a MacRumors Posting
    about this recent Apple Security Update which caused an issue with the drivers for both OS X 10.9 and 10.10. NVIDIA issued a new driver for 10.10 to resolve the issue and MacVidCards figured out a fairly simple fix for 10.9. They said to sure to follow the instruction exactly:
    https://forums.macrumors.com/showpost.php?p=20819134&postcount=33
    I did this, and it worked, evidently, since then there is a new driver from NIVIDA. I’ll look at that tomorrow.
    But, in the meantime, I noticed that my MAC Activity Monitor was showing up around 185% CPU usage for Premiere Pro, when the sequence was playing,
    and the Adobe QT32 Server (Not Responding) which was in red, was showing 145% CPU usage when I was exporting the file.
    Now I would presume that these should be well under 100% RAM usage was relatively low.
    I would think the freezing and stuttering would somehow be related to this?
    Any help would be appreciated, and I thank you all for your time in advance.
    Regards,
    Barry O’Brien
  • Page 1 of 2
