Activity › Forums › Adobe Premiere Pro › Adobe Pr.Pro CS5 Sequence Presets
  • Adobe Pr.Pro CS5 Sequence Presets
    Posted by Ashraf Aziz on May 19, 2011 at 1:02 pm
    Hi all,
    I would be very grateful if you would:
    1) define to me in brief the different Adobe Pr. Pro CS5 sequence preset video formats (which of them are compressed and which are uncompressed .. editable or non-editable etc.) to enable me to better select the most appropriate high quality format.
    2)Is there a way to know in Adobe Pr. Pro CS5 what is the format of the video captured from Open to air satellite using the Black Magic Intensity Shuttle ?
    3)If I shoot my video with AVCHD full HD format (Panasonic) , which sequence setting do I choose if I want to prepare my footage to be broadcasted on a local PAL HD satellite ?
    Thank you for your time and willingness to help
    Best regards,
    Ashraf
    Ashraf Aziz replied 15 years, 4 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    May 20, 2011 at 1:20 am
    [Ashraf Aziz] “1) define to me in brief the different Adobe Pr. Pro CS5 sequence preset video formats (which of them are compressed and which are uncompressed .. editable or non-editable etc.) to enable me to better select the most appropriate high quality format. “
    Premiere Pro handles everything natively – it doesn’t compress anything at all. If you build a preview/render, it gets thrown out, and redone at the final output quality (unless you force it to do otherwise.)
    [Ashraf Aziz] “2)Is there a way to know in Adobe Pr. Pro CS5 what is the format of the video captured from Open to air satellite using the Black Magic Intensity Shuttle ?
    The moment it’s captured, it’s based on your capture settings, and no long whatever format is Open to air Satellite.
    [Ashraf Aziz] “3)If I shoot my video with AVCHD full HD format (Panasonic) , which sequence setting do I choose if I want to prepare my footage to be broadcasted on a local PAL HD satellite ?”
    Match the footage to a sequence preset. Use whatever format they tell you via the export Media or Adobe Media Encoder at the end of the chain.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Ashraf Aziz
    May 20, 2011 at 8:41 am
    Thanks a lot for your time. I appreciate your kind help.
