Activity Forums Adobe Premiere Pro Adobe Premiere Pro Video Lag – HVX200 (video slow / audio normal)
  • Adobe Premiere Pro Video Lag – HVX200 (video slow / audio normal)
    Posted by Nathaniel Elliott on August 4, 2011 at 1:55 am
    These are the information interpreted from the footage I imported into Premiere. The footage I believe came from a HVX200 (something). It was given to me in a .mov file
    File Path: /Users/editor/Desktop/video/0260GJ.mov
    Type: QuickTime Movie
    File Size: 4.4 GB
    Image Size: 960 x 720
    Pixel Depth: 24
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz - 16 bit - Mono
    Project Audio Format: 48000 Hz - 32 bit floating point - Mono
    Total Duration: 00:13:24:09
    Average Data Rate: 5.6 MB / second
    Pixel Aspect Ratio: 1.3333
    QuickTime Details:
    Movie contains 1 video track(s), 4 audio track(s) and 1 timecode track(s).
    Video:
    There are 19305 frames with a duration of 125/2997ths.
    Video track 1:
    Duration is 0:13:25:04
    Average frame rate is 23.98 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 960 x 720
    Compressor = DVCPRO HD 720p60
    Quality = Normal (3.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 16 bit - Mono
    Rate = 48000 Hz
    Compressor = 16-bit Little Endian
    Audio track 2 contains 1 type(s) of audio data:
    Rate = 48000 Hz
    Audio track 3 contains 1 type(s) of audio data:
    Rate = 48000 Hz
    Audio track 4 contains 1 type(s) of audio data:
    Rate = 48000 Hz
    Timecode:
    Timecode track 1 contains 1 type(s) of data:
    Timecode data block #1:
    Start Time = 08:14:29:00
    Reel name = Spanned Reel
    My settings are set to match this for my sequence under DVDPROHD 720 (60). The problem is that the audio sounds normal but the video is running extremely slow and even when I export it out, the video doesn’t match the audio. I can’t figure out what to do and don’t know what camera this was shot on exactly but I know it was an HVX200 something… Any ideas would be greatly appreciated, it was shot on p2 cards but are mov files already (not sure how). I just got the footage and now need to edit it, thanks!
    Gary Huff replied 14 years, 9 months ago 3 Members · 5 Replies
  • Nathaniel Elliott
    August 4, 2011 at 12:43 pm
    Any ideas concerning this?
  • Gary Huff
    August 4, 2011 at 1:34 pm
    Please clarify this. Are you in a 60p sequence or a 24p sequence?
  • Nathaniel Elliott
    August 4, 2011 at 8:39 pm
    60
  • Ben G unguren
    August 5, 2011 at 2:36 pm
    A good rule of thumb is to get all clips into exactly the same format as your timeline (video & audio codec, sampling rate, frames per second, etc). If I were you, I’d take the problematic video clip into Quicktime Pro (if you still have it) or After Effects and render it out to the exact specs of your editing timeline.
    Of course, you don’t HAVE to do this all the time, but you sure will have a lot fewer problems if you do…. I suggest you give that a try and see if you still have the problem with video lag.
  • Gary Huff
    August 5, 2011 at 3:41 pm
    Why are you in a 60fps sequence when your footage is 24fps?
