Activity › Forums › Adobe Premiere Pro › ADOBE PREMIERE PRO NEW REFERENCE MOITOR
Posted by Old Git on November 2, 2005 at 5:59 pmIF I OPEN THE NEW REFERENCE MONITOR, SHOULD I BE ABLE TO PLAY THE TIMELINE. AND VIEW IT IN, THE (NEW REFERENCE MONITOR) AS A MOVIE.
Don Huckleberry replied 20 years, 11 months ago 3 Members · 3 Replies -
Tim Kolb
November 2, 2005 at 9:20 pmHaving the normal monitor AND a reference monitor open slows playback considerably on most systems.
TimK,
Kolb Syverson Communications,
Creative Cow Host,
2004-2005 NAB Post Production Conference
Premiere Pro Technical Chair,
Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
“Premiere Pro Fast Track DVD Series” http://www.classondemand.net -
Old Git
November 2, 2005 at 9:52 pmWITH THE REFERENCE MONITOR OPEN, I PLAY THE TIMELINE, THE REFERENCE MONITOR STAYS ON THE FIRST CLIP THEN WHEN I STOP THE TIMELINE THE REFERENCE MONITOR JUMPS TO THE LAST CLIP, WITH NO MOVEMENT IN BEETWEEN IS THIS CORRECT OR SHOULD THE MOVIE PLAY ALL THROUGH
Don Huckleberry
November 2, 2005 at 10:38 pmHi,
When you open the new refrence montior, you also have to “Gang to Program Monitor”. This is under the triangle on the upper right of the reference monitor. It should work for you now. Typically, you would use one monitor (the program for example) to watch the video and the ref mon would be to view scopes. Or vice versa.
Hope this helps,
Don
