Activity Forums Adobe Premiere Pro Adobe Premiere Pro “Media pending” glitch in the export
  • Adobe Premiere Pro “Media pending” glitch in the export
    Posted by Jim Turner on December 10, 2015 at 2:07 pm
    Hi all. This glitch has been driving me mad for hours. When exporting to h264, 99% of the video is fine, but for a split second near the end, 3 assets all show “Media pending” in the export (screenshot attached), accompanied with an audio hiccup. The video plays fine in the timeline.
    These are export settings I use all the time, and assets that I’ve used before. Nothing is weird in the timeline; it’s a pretty straightfoward edit. And after that split second, all three assets pop in and everything is fine again.
    This happens when exporting with AME; when I try to export with PPro, it actually crashes when it hits that spot in the export process. Computer is OS X Yosemite, with plenty of RAM and CPU horsepower.
    Troubleshooting that I’ve tried:
  • Deleting cache and render files
  • Restarting the computer
  • Updating Premiere Pro CC 2015 to 9.1.0
  • Forcing that section to pre-render in the timeline
  • Copying entire sequence to a fresh timeline
  • Nesting the problematic section
  • Monkeying with different export settings (CBR/VBR, bitrate, h265)
  • Moving the entire sequence down the timeline (so it starts at 8:00:00 instead of 00:00:00, thereby avoiding the troublesome 6:18:00 spot)
  • Jedi mind trick
  • The best part is that if I export only 10 seconds right around the glitch, it’s fine. So I know the assets are fine, and in order to troubleshoot I have to export the entire thing. (This is also why I tried moving the sequence within the timeline).
    Any thoughts? I am completely out of ideas.
Jim Turner replied 10 years, 8 months ago 2 Members · 3 Replies
    • Merlin Vandenbossche
      December 10, 2015 at 5:18 pm
      Hey Jim,
      We once had a very persistent thing like this involving audio. Timeline would play fine, but every export this one file went missing (like ‘pending’). I believe our eventual workaround was to transcode the piece of media so it would become a new piece of media (in case of this audio just from WAV to WAV actually). Then re-import and re-edit it in (I believe we did manually re-edit, not relink).
      Maybe premiere does not recognize the header/start of this clip (anymore) during exporting and thinks it pending/offline. So maybe another instance (re-encoded) would. Good luck!
      Merlin
    • Jim Turner
      December 10, 2015 at 6:04 pm
      Thanks, Merlin!
      I just tried something similar, which still failed to fix the problem. I didn’t go as far as transcoding the assets, but here’s what I did:
    • Created a new, empty sequence from scratch
    • Copy/pasted most of the timeline, up to a little bit before the glitch
    • Duplicated the 3 assets on the hard drive and imported into Premiere
    • Manually rebuilt the entire ending with the duplicated assets, using different in-points
    • All that, and still the same problem. Right now I’m taking a different approach, and I’m just deleting the assets one at a time and trying the export, to see if I can determine which one is causing the problem. Will post again if I find a solution.
      Thanks again!
  • Jim Turner
    December 10, 2015 at 8:17 pm
    Well, this is just a nightmare. I’ve decided it’s cursed.
    Long story short, I determined which asset was causing the problem by deleting things until an export worked. Then, after several iterations, I eventually replaced that video asset with a still image — and it STILL happens. It’s as if simply having three things in that particular configuration on the screen causes the glitch. It makes absolutely no sense.
    Nevertheless, the only solution I have found is to remove one of the assets entirely and reconfigure the screen with only 2 assets. It doesn’t seem to matter which 2 I keep — as long as there are only 2.
    If anyone can provide some insight, I would love to know what is actually happening. But for now, I can’t keep screwing with this, so this is now the final version.
    Thanks again, Merlin, for your help!
  • We use anonymous cookies to give you the best experience we can.
