Activity Forums Adobe Premiere Pro Adobe Premiere Pro keyframe position & scales problem
  • Adobe Premiere Pro keyframe position & scales problem
    Posted by Merlin Merton on December 18, 2012 at 3:52 pm
    I’m working on a project for a client who asked that I place a photograph that moves slowly across the screen. I’ve put keyframes either end of the photographs ‘effects’ timeline. However, when I play it back for some reason, the photograph begins and ends in the correct places, but it won’t simply follow the route but goes back on itself in the middle…like a bouncing ball, instead of moving in a direct way.
    It’s hard to explain, but basically instead of moving slowly from right to left in one motion, it moves right-left-right (a little)-left (to the end)!
    Is there some function I need to unclick or something perhaps??
    Many thanks for any help, but this is very frustrating!
    Merlin Merton replied 13 years, 8 months ago 3 Members · 6 Replies
  • Sam Comer
    December 18, 2012 at 4:25 pm
    Are you sure there are only two keyframes there?
  • Kris Merkel
    December 18, 2012 at 4:41 pm
    Try changing the keyframes to “Linear” and see if you get the same result.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Merlin Merton
    December 18, 2012 at 4:43 pm
    There are four. First is at the beginning, second is five frames in, third is five frames from the end, and the final one is at the end.
    I wanted to make the photograph move in from outside the frame quickly, then move slowly for a few seconds, before disappearing out of frame again at the end. I’ve done it before a while ago, but it doesn’t seem to work anymore on CS5! For some odd reason, it does a side-ways bounce in the middle which ruins the simpler effect I was going for in the first place.
    Do you know how I might solve this??
    Thanks in advance!
  • Merlin Merton
    December 18, 2012 at 4:44 pm
    Hey thanks for this…where on the CS5 version do you change keyframes to linear??
  • Sam Comer
    December 18, 2012 at 4:45 pm
    Right click on the key frame and a dropdown menu should come out.
  • Merlin Merton
    December 18, 2012 at 4:47 pm
    Just done it! Many thanks for your help Chris and Sam!
