Activity Forums Adobe Premiere Pro Adobe Premiere Pro: Horrible sound when exporting a sequence
  • Adobe Premiere Pro: Horrible sound when exporting a sequence
    Posted by Andrew Marchand on October 12, 2006 at 11:55 pm
    Hi, I am having a big sound issue when exporting a sequence in Premiere Pro. Im editing a skateboarding video and I get a very loud scratchy noise on clips where you can here the skateboard wheels on the concrete. So it seems to be happening on clips with more treble. Does anyone know how to fix this?
    Chris Dolan replied 19 years, 11 months ago 4 Members · 3 Replies
  • Vince Becquiot
    October 13, 2006 at 2:00 am
    Are your mixer meters hitting the red ?
    Vince
  • Mike Velte
    October 13, 2006 at 11:30 am
    Vincent is on target. Clipped audio often sounds fine when previewed from Pro, but awfull when played in the clients player.
  • Chris Dolan
    October 13, 2006 at 12:16 pm
    I’ll second Mike’s statement. I usually need to decrease audio in the timeline. Play your timeline with the audio meter palate open. If it’s peaking above -6, or ‘redlining’ as I call it, you’re going to have problems with the finished DVD. Try to adjust your audio level so it averages between -12 and -6 on the meters, peaking not much more than -6. I find that DVD authoring software such as Encore DVD seems to boost the audio a little. What is fine in the PPro timeline is often much louder on the final DVD.
    Good luck…
