Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro Error
  • Adobe Premiere Pro Error
    Posted by Jason Boone on February 26, 2008 at 1:24 am
    While editing in Premiere CS3 (Education), playback will freeze up occasionally. It happens in both the Program and Source windows. When I press spacebar or play, the blue icon will switch from “stop” to “play,” but it will not playback. Nothing happens.
    If I scrub the playhead it will sometimes fix the problem. But other times it stays frozen. The other day it kept freezing up playback, even after several reboots. Any reason why? Probably something simple that I am overlooking.
    Here are the specs:
    MacBook Pro
    10.4.11
    2 GB 667 MHz DDR2 SDRAM
    Intel Core 2 Duo
    Premiere Pro CS3 (Education Version)
    Thank you for any help.
    Jason Boone replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
