Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro CS5 preview playback glitches and publishing
  • Adobe Premiere Pro CS5 preview playback glitches and publishing
    Posted by Jordan White on May 21, 2011 at 10:37 pm
    When I preview my project in Adobe Premiere Pro CS5, I notice dropped frames, mostly with quick moving subjects or the start of a video. I played around with Mercury for a while, yet turned out unsuccessful in getting the dropped frames or stutter to disappear. Another problem that I have is that when I publish the file, the exact way the preview turns out, especially with stuttering playback and dropped frames, is the exact way the output file is going to look like. I point the culprit to file clutter, yet is there a way to fix it as registry or Adobe Premiere Pro program investigation. I tried setting the playback option from Performance to Memory, yet that didn’t work. May you please help me with this.
    Todd Kopriva replied 15 years, 4 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 23, 2011 at 2:13 pm
    What happens if you render preview files for the problematic part of the sequence?
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
