Activity Forums Adobe Premiere Pro adobe premiere pro cs4 problems
  • adobe premiere pro cs4 problems
    Posted by Sheikh Nazim on January 2, 2010 at 4:54 pm
    hi,
    im using premiere pro cs4 and when i want to render it out to mpeg 2 the video goes blurry at the end of the rendering,also the text is barley readable. the actual file (the uploaded/captured file) is super quality no problems, its just when i render it, it ends up becoming blurry and distorted. why does that happen? has anyone else faced this problem?
    i use the following formats
    video:
    mpeg 2
    video frame size 720 x 576
    bitrate constant 6mpbs
    aspect ratio 4:3
    field: top filed first
    frame rate 25
    audio:
    mpeg
    layer 2
    bitrate 192kbps
    frequency: 48khz
    mode stereo
    crc: on
    please help, i have been facing this problem for some time now and would like to get some answers.
    Brian Louis replied 16 years, 8 months ago 2 Members · 1 Reply
  • Brian Louis
    January 2, 2010 at 6:39 pm
    [Sheikh Nazim] “the actual file (the uploaded/captured file) is super quality no problems”
    What is your source footage that you are converting to Mpeg?
