Activity Forums Adobe Premiere Pro Adobe Premiere Pro AVCHD-PROXY
  • Adobe Premiere Pro AVCHD-PROXY
    Posted by Mark Torke on April 30, 2009 at 9:50 pm
    Hi, my videos are in AVCHD format and in Adobe Premiere CS4 it can be used in its native format, but not efficiently. In After Effects CS4 I was able to get it running fine with the use of a Proxy, but in Premiere it doesn’t seem to have the feature…is there anyway to get it to work well?
    Arc Nevada replied 17 years, 4 months ago 3 Members · 3 Replies
  • Jon Barrie
    April 30, 2009 at 11:19 pm
    AVCHD requires a gutsy computer system with a tonne of ram and RAID 0 style HDD content playback. If your computer meets the minimum specs or below there is no way to make it perform true realtime without a hardware upgrade.
    There are a couple of things you can do to minimise the applications ram usage which might give you better results.
    – Twirl up the Video and Audio tracks so you don’t see the head/tail thumbnail for video clips and the waveform for audio in the timeline.
    – Work in Draft mode.
    – Generel Preferences are set to “performance”, close PPro/restart PPro.
    Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Mark Torke
    April 30, 2009 at 11:41 pm
    Thanks for the response…Well my system is the following:
    EVGA 750i Motherboard
    Q6600 Quad Core 2.4GHz
    4GB DDR2 1066
    XFX 9600 GT w/ 512Mb
    As for raid 0, how would i set that up to improve my performance…
  • Arc Nevada
    May 6, 2009 at 6:19 pm
    You do not need a striped RAID configuration to edit AVCHD in it’s native format. If you used the Cineform converter a RAID would let you play several layers at once.
