Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro and Handbrake Problems
  • Adobe Premiere Pro and Handbrake Problems
    Posted by Jordan White on July 28, 2011 at 12:22 pm
    I’m using a program called Handbrake to get footage off of DVDs and it works well, but when I try to import the file in Adobe Premiere Pro, it reads the file as having 90000 fps! I’m encoding my files in the H.264 format in Handbrake. When I encode the files as MPEG-4 ffmpeg, the footage is read correctly in Adobe Premiere Pro. I discovered that the problem is with Handbrake itself. I’ve tried uninstalling it and deleting the registry values, but that didn’t work. I’ve tried deleting the AppData folders in Windows 7, but that didn’t work either. I did find a workaround by reencoding the files in Avidemux, but I want to make sure it directly encodes in Handbrake so that when I import the Handbrake encoded footage into Adobe Premiere Pro, the file has the correct framerate so that not only will not be so super short, but have the audio attached to it as well.
    Morgan Simpson replied 13 years, 7 months ago 4 Members · 3 Replies
  • Stefan Kamp
    July 28, 2011 at 8:16 pm
    Try mpeg streamclip instead?
    stefan kamp
    fiction/documentary
  • Robert Owen
    January 28, 2012 at 5:58 pm
    If you turn off the peek frame rate (VFR) setting it fixes this. Adobe does not know how to recognize it in a file. Also you may try setting the frame rate to 29.97 instead of using “same as source”.
  • Morgan Simpson
    January 30, 2013 at 10:58 pm
    Thank you for posting this answer. I appreciate it.
