Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro 2.0 – titler effect
  • Adobe Premiere Pro 2.0 – titler effect
    Posted by Jonnyyao on February 3, 2006 at 5:03 am
    Dear all,
    I download the try version of Adobe Premiere Pro 2.0 form the Adobe web site.
    After runing the program and invoke the titler dialog box, the AP will crash.
    The titler can work well in Adobe Premiere Pro 1.5.
    Does anyone has the same situation just like me?
    Any solution? Please help me, thank you.
    Tim Kurkoski replied 20 years, 7 months ago 3 Members · 5 Replies
  • Aanarav Sareen
    February 3, 2006 at 5:34 am
    System specs?
  • Jonnyyao
    February 3, 2006 at 6:16 am
    I list the system specs here, including basic system information and display Device.
    System Information
    Time of this report: 2/3/2006, 14:11:31
    Machine name: 910815-JOHNNYNB
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
    Language: Chinese (Regional Setting: Chinese)
    System Manufacturer: ASUSTeK Computer Inc.
    System Model: M3N
    BIOS: Default System BIOS
    Processor: Intel(R) Pentium(R) M processor 1500MHz
    Memory: 502MB RAM
    Page File: 348MB used, 880MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    Display Devices
    Card name: Intel(R) 82852/82855 GM/GME Graphics Controller
    Manufacturer: Intel Corporation
    Chip type: Intel(R) 82852/82855 GM/GME Controller
    DAC type: Internal
    Device Key: Enum\PCI\VEN_8086&DEV_3582&SUBSYS_17421043&REV_02
    Display Memory: 64.0 MB
    Current Mode: 1400 x 1050 (32 bit) (60Hz)
    Monitor: Monitor Max Res: 1600,1200
    Driver Name: ialmrnt5.dll
    Driver Version: 6.14.0010.4020 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 1/23/2005 10:56:00, 37951 bytes
    WHQL Logo’d: Yes
    WHQL Date Stamp: n/a
    VDD: Mini VDD: ialmnt5.sys
    Mini VDD Date: 1/23/2005 11:05:06, 804317 bytes
    Device Identifier: {D7B78E66-76C2-11CF-477C-4837A3C2CB35}
    Vendor ID: 0x8086
    Device ID: 0x3582
    SubSys ID: 0x17421043
    Revision ID: 0x0002
    Revision ID: 0x0002
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
  • Tim Kurkoski
    February 3, 2006 at 5:55 pm
    This strikes me as a font problem. Try unloading extra fonts from your system fonts folder and see if that helps.
  • Jonnyyao
    February 3, 2006 at 8:02 pm
    Dear Timothy Kurkoski,
    Yes, you right. It’s font problem.
    After unloading some fonts, it can work correctly.
    But these fonts are installed by Microsoft Office 2003, it’s unreasonable.
    The language version of Microsoft Office 2003 is Traditional Chinese.
    I hope Adobe can fix it in next patch.
    However, I deeply appreciated your help.
  • Tim Kurkoski
    February 3, 2006 at 8:20 pm
    One of the fonts may be damaged. Try reinstalling Office.
    Also, sometimes simply taking fonts out, restarting the computer, then putting them back in can fix problems. It forces Windows to rebuild some font cache data, and that may be where the problem is.
    Also, Premiere may not be compatible with all double-byte fonts. Since Adobe doesn’t produce a Chinese version of the application, I doubt they’ve tested it with all the Chinese fonts out there.
