Activity Forums Adobe Premiere Pro Adobe Premiere Pro 2.0 Media Management
  • Adobe Premiere Pro 2.0 Media Management
    Posted by Drekar42 on April 27, 2006 at 4:06 am
    I tried a search and came up with some information in regards to long-from editing but I was wondering also about large bins and a high number of clips. Does Premiere Pro really bog down?
    Dave
    Mark Palmos replied 20 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
  • Aanarav Sareen
    April 27, 2006 at 4:44 am
    I haven’t had any performance reduction with large clips and I frequently work with projects that have over 15 hours of footage.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • David Cherniack
    April 27, 2006 at 1:32 pm
    My experience with 45 hours of material for a documentary, a few thousand clips and 2 levels of sub-timelines: I’d prefer having 32 root canals.
    Anyone starting a very large project should keep in mind the following:
    Because media management is rudimetary and memory management is still not completely fixed, design your workflow so that you can easily split it up into multiple projects if you run into trouble. Keep sub-timelines to one layer or not at all. If you’re planning on re-ingesting your material at a higher rez, remember that all timelines in the project (whether sub or not) count as part of the project trim. Finally have a voodoo doll representing the architects of the software standing by. You may need it.
    David
    AllinOneFilms.com
  • Victorypoint
    April 27, 2006 at 2:56 pm
    David, are your issues likely related to hardware or are you working with a pretty smoking machine? What kind of footage? Any add-ons (e.g. Aspect-HD, Matrox Axio, etc)? Any bottlenecks that should be avoided?
    -AJ
  • Troy Murison
    April 27, 2006 at 9:11 pm
    I have used PPro recently for projects with hundreds of individual clips, but the
    timelines aren’t too long (10-ish minutes) without any hardware assist (DV).
    My experience is mainly w/1.5, not 2.0 yet. I found that, in general, the number
    of clips didn’t slow it down TOO much (except for loading the project on startup)
    but the more versions I saved as seperate sequences, the more sluggish and more
    tempramental it would get. After working for a while and producing several
    versions of a cut by duplicating the sequence, then continuing in the new one,
    I would get predictable crashes when either beginning to edit or trying to render
    in the new sequence. A restart of PPro using it’s ‘copy’ of the project usually
    righted the ship, but once this had happened in a project, every time I duped the
    sequence and moved on, crash. This happened on several different projects.
    But, I have to say my experience wasn’t too different (other than the crashes)
    from other systems I have used (sluggishness-wise) given my particular project type.
    Maybe slightly more sluggish than FCP, but I haven’t used 5.0.x for this type of
    project. Avid systems on similar projects seem to be slightly better than FCP.
    I found too that a regular (twice-ish daily) restart of PPro really helped if
    it hadn’t already crashed from the ‘duping’ thing. The last project I did, I tried
    deleting old sequences that weren’t relevant any more and that SEEMED to help a
    little too (not with the dupe crash though, just sluggishness). The dupe crash
    I mentioned is repeatable on different systems too BTW (at least for me). It may
    be that a longer timeline with the density of cuts I have may get more sluggish
    too, but I don’t know.
    PPro’s bin structure with that many source clips really is limiting though for me.
    Not being able to open more than one bin window is very frustrating,
    especially when browsing bins as thumbnails. Just my .02!
    -Troy Murison
    Flyingspot, Seattle
  • Mark Palmos
    April 28, 2006 at 2:35 pm
    [David Cherniack] “Keep sub-timelines to one layer or not at all.”
    Hey there David,
    do you mean keep it to one sub-timeline depth, or to have only one layer of source on a sub timeline?
    [David Cherniack] “I’d prefer having 32 root canals.”
    does that include an alpha canal?
    later
    mark
  • David Cherniack
    May 3, 2006 at 2:24 pm
    Sorry for the delay in answering. I’ve been wrestling with the monster (PPro) and am writing this while the project is re-loading for the 4th time today. (it’s 10am)
    Victory, I’m editing on an Axio running an HP 9300 with dual-dual 275 Opterons and 3 gigs of ram. It’s a smoking system and I hate to think what shape I’d be in if I was on anything less. The issue is the memory management architecture of PPro, nothing else. Adobe is well aware of the problem but has chosen not to completely fix it yet – I guess because it only effects those with really large projects or who are running lots of large graphics.
    I can only re-iterate – if contemplating a large project proceed in a way that you can easily break it up. I began my project in 1.5 assuming that the memory management was so poor Adobe would fix it in 2.0. While they did improve it, it is no way completely fixed as my numerous restarts attest. As I’ve pointed out elsewhare Matrox provides a utility to monitor memory usage by PPro. I can usually see when I’m about to hit the wall and restart before PPro crashes.
    They really have to fix this if they expect to be taken seriously by long formers. Would the time I save by Axio’s real time be worth the frustrations of PPro? I’m not sure but I have my doubts. The frustartions at this point in my project are immense and are starting to get me down.
    David
    AllinOneFilms.com
  • David Cherniack
    May 3, 2006 at 2:29 pm
    [Mark Palmos] “do you mean keep it to one sub-timeline depth, or to have only one layer of source on a sub timeline?”
    I mean one sub-timeline in depth ie no subtimelins inside sub-timelines. That Helps PPro’s speed and memory management issues with long sub-timelines. It also allows relatively efficient trimming of projects. Unfortunately, with my double system sound in this project, I couldn’t do that. My 17 hours of interviews became 17 hours of subtimelines.
    Alpha canals? They can be more painful than root canals.
    David
    AllinOneFilms.com
  • Mark Palmos
    May 7, 2006 at 10:23 pm
    [David Cherniack] “Alpha canals? They can be more painful than root canals.”
    yep, they hurt quite a bit, at least 8.
    catcha later david,
    mark.
