Activity › Forums › Adobe Premiere Pro › adobe premiere pro 1.5 – cutting lines into images?
  • adobe premiere pro 1.5 – cutting lines into images?
    Posted by Release2 on March 20, 2007 at 9:16 pm
    Hopefully this is my last problem with premiere, but it’s something that’s been bugging me. Sometimes it seems as if premiere is cutting horizontal lines out of some of my video tracks. Sometimes it shows the lines actually cut out in the preview window, and then other times, everything looks fine until I export it, and for example the last 1 or 2 frames of a scene, one layer has lines cut out of it (but every frame looks perfect in the preview).
    The effect is like this, a horizontal line that goes all the way across, and 1 pixel tall, is “cut” out of a layer, the next 1-pixel layer down displays normally, then the next ones cut out, next normal, etc.
    The most noticeable place is a “bug” i’ve animated on its own track. It was just a soft-edge brush dot in Photoshop of white/yellow color, and I’m using the .psd file directly. I animated it around in premiere so it looks something like a will-o-wisp. The soft edges of it have the previously mentioned lines cut out of it, in the preview, and in the render. Any ideas what is causing these cut out lines? It’s a neat effect but I’m not wanting to do it! 🙂
    My general properties are:
    Editing mode: Video for Windows
    Timebase: 30 frames/second
    Frame size: 320 x 240
    Pixel aspect: Square Pixels (1.0)
    Fields: lower field first
    Display: 30 fps
    Release2 replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
