Activity › Forums › Adobe Premiere Pro › Adobe Premiere Pro 1.5 close down due to error
  • Adobe Premiere Pro 1.5 close down due to error
    Posted by Daniel on September 6, 2005 at 12:00 pm
    I’m using Decklink extreme in PC environment.
    Generally it was very smooth with PC platform.
    But I found that there several issue that i’m
    facing now as below:
    1) In a blackmagic DV project setting, Adobe Premiere
    Pro 1.5 will force to close down due to serious error.
    I am able to reproduce the problem when i’m trimming
    the clips using CTRL+drag the edge of the clip several
    time then this problem will occur.
    2) In a blackmagic DV project setting, Adobe Premiere
    Pro 1.5 having long time importing avi files into project.
    3) When using Adobe Photoshop CS2, when i fill a selected
    area, Adobe photoshop hangs.
    Kindly share some lights on the above issues.
    Daniel lai
    Daniel replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
