Activity Forums Square Box CatDV Adobe Premiere Panel Issue
  • Adobe Premiere Panel Issue
    Posted by Alex Schmidt on October 21, 2016 at 3:10 pm
    Hello everyone!
    I am currently having an issue with the Adobe Premiere Panel; it is not allowing me to connect to my CatDV Server. Here is the process I followed:
    1. I installed the Premiere Panel along with the extension feature (from Adobe Creative Cloud).
    2. Restarted Computer.
    3. Opened up Premiere Pro CC, clicked on “Window”>”Extensions”>”CatDV”
    4. I have one text field that only allows me to type in the “CatDV Server:”.
    5. I typed in the Server Address (not the default localhost) that the Desktop Client is connected to, and it just sits on “Connecting..”
    What am I missing? I noticed that in the video from Squarebox there are three fields that ask for “CatDV Server:”, “Username” and “Password”, however I only have the one “CatDV Server: field” to enter in the Premiere Panel.
    We are on CatDV server 7.1.0.
    Any help would be appreciated, thank you!
    Alex Schmidt replied 9 years, 9 months ago 2 Members · 3 Replies
  • Alex Schmidt
    October 21, 2016 at 3:55 pm
    Additionally, we have the Adobe Creative Cloud for Teams, not Enterprise if that makes a difference. There was mention of supporting “Adobe Anywhere” which I noticed is only available to Adobe Enterprise memberships.
  • Dougal Matthews
    October 25, 2016 at 10:57 am
    hi Alex
    you need to supply address and port
    so if your ip was 192.168.1.2 and your catdv webserver was running o nthe default port 8080
    you’d need to use 192.168.1.2:8080
    or if you had a hostname of catdvserver
    you’d use catdvserver:8080
    there’s also some good guidance on the panel here which may be useful
    https://www.squarebox.com/premiere-plugin/
    thank you Dougal
    Improvise Adapt and Overcome
  • Alex Schmidt
    October 25, 2016 at 8:35 pm
    Perfect! It worked, thank you! I had to use a different port # in the end; I was not aware you had to include that.
    Thank you!
