Activity › Forums › Adobe Premiere Pro › Adobe Premiere only allows DVCPro50 not DVCPro60 export
  • Adobe Premiere only allows DVCPro50 not DVCPro60 export
    Posted by Susan Johnson on October 18, 2011 at 2:19 pm
    Two issues- I have a 41 minute video that says on the original footage that it is 1280 x 720 in a 1.3 ratio but when I import it into Premiere Pro CS5 it is saying it is 960 x 720. Even when I try to interpret the footage, it does not give me the options to change it. The only option is gives me is to make it 1.5
    Also, I am trying to export the video and my clients want a .mov file with a HD DVCPro60p codec
    However, Adobe Media encoder will only let me export this with a HD DVCPro50p codec. If I try to use the 60p codec, it just stays at 0% and nothing changes.
    Please help!
    Susan Johnson replied 14 years, 11 months ago 3 Members · 5 Replies
  • John-michael Seng-wheeler
    October 18, 2011 at 3:51 pm
    To answer your first question,
    The file is 960×720, which, when stretched horizontally by 1.3, (actually 1.333 ect. It’s usually just written 1.3) comes out to 1280×720. That’s how the DVCPRO HD codec works. PP is interpreting the file correctly, there’s nothing you need to do.
    As for the second problem, I have any ideas at the moment.
    Any more info you can provide about the output settings you’re using?
  • Shane Ross
    October 18, 2011 at 8:51 pm
    There Kano such thing as DVCPRO 60. And DVCPRO 50 is an SD format, not HD.
    Shane
    October 18, 2011 at 8:55 pm
    I think he’s talking about DVCPRO HD 720/60p vs 50p
    Like I said before… we need more information about the rendering settings she’s using before we can help…
  • Shane Ross
    October 18, 2011 at 9:04 pm
    If it’s 50p vs 60p…that’s a frame rate issue. 50fps vis 59.94. That’s a whole different beast.
    Shane
  • Susan Johnson
    October 19, 2011 at 11:29 am
    When I go to export media, I am rendering as a .mov file and choosing the custom setting. I try to export using a DVCPRO HD 720p60 and is just stays at 0% for hours. If I choose DVCPRO HD 720p50 is will export within about an hour and a half. It will play fine when the speaker remains still, but when he starts walking across the stage, it looks funny when he walks.
    One odd part, when I test out just a few minutes of the 41 minute video, it will allow me to use the 60 codec, but when I try to export the whole project, it just hangs up.
