Activity Forums Adobe Premiere Pro adobe premiere export multi format
  • adobe premiere export multi format
    Posted by Nick Hartcher on October 4, 2019 at 1:57 pm
    hey team,
    I am currently have multiple projects and sequences in premiere that I need to export so that I can send to various people so that they can edit in thier own programs such as Final Cut Pro
    what is the best format and settings to do this without sending the original RAW video files to them?
    thanks in advance Nick
    Blaise Douros replied 6 years, 11 months ago 3 Members · 4 Replies
  • Blaise Douros
    October 4, 2019 at 9:44 pm
    If they don’t have the media, they can’t edit it. Are you suggesting that you’d like to transcode all the media to a smaller-file-size codec, and send it to them along with the sequence? If so, Adobe Media Encoder will batch export them. You can also render proxies via Premiere’s proxy workflow.
  • Greg Janza
    October 4, 2019 at 9:49 pm
    This is potentially asking for a lot of headache, Is it absolutely necessary for the projects to be worked on outside of Premiere?
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Nick Hartcher
    October 8, 2019 at 10:53 am
    ok great thanks for the reply. yes which setting should I use to output at maximum quality?
  • Blaise Douros
    October 8, 2019 at 4:12 pm
    Maximum quality and file portability are mutually exclusive. Use ProRes or DNxHD at the native resolution for a visually lossless transfer, but don’t expect it to be small.
