Activity Forums Adobe Premiere Pro Adobe Premiere. Divide screen to many separated screens
  • Adobe Premiere. Divide screen to many separated screens
    Posted by Bonifacy on April 6, 2007 at 11:25 am
    Hi. I’m a newbie…
    I want to make a clip, where the screen is divided into 4×4 separate screen’s set.
    How can I do it? help me please.
    Bonifacy replied 19 years, 5 months ago 2 Members · 2 Replies
  • Steven L. gotz
    April 6, 2007 at 3:50 pm
    You put all four clips on to video tracks 1 through 4.
    Put the clip you want in the upper left on track one, upper right on track two, bottom left on track 3 and bottom right on track 4. (These are arbitrary but follow these steps first, you can change things later.) You may wish to create a video track 4 in advance, or you can just drop the clip into the gray area above track 3 and it will create track 4 for you.
    Select the clip on track one. Look in the Effects panel and apply the first preset under PiPs, 25% PiPs, 25% UL – named PiP 25% UL
    Select the clip on track two. Apply the first preset under PiPs, 25% PiPs, 25% UR – named PiP 25% UR
    Select the clip on track three. Apply the first preset under PiPs, 25% PiPs, 25% LL – named PiP 25% LL
    Select the clip on track four. Apply the first preset under PiPs, 25% PiPs, 25% LR – named PiP 25% LR
    That should do the trick. After you understand how to use the standard PiPs, you can use the presets that scale in and out and spin, etc.
  • Bonifacy
    April 6, 2007 at 7:31 pm
    Tanks, I solve the problem!
