Activity Forums Adobe Premiere Pro Adobe Premiere CS6 – Imported footage is brighter?
  • Adobe Premiere CS6 – Imported footage is brighter?
    Posted by Cl Beu on March 21, 2013 at 6:10 am
    Hey y’all, just imported some footage into Adobe Premiere CS6, and the footage seems to be significantly brighter than when I view the same (untouched) footage in Daum PotPlayer. Any clue as to the reason why, and how to revert it back?
    Thanks a million
    Cl Beu replied 13 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Ann Bens
    March 21, 2013 at 8:50 am
    Never heard of the player.
    I would go for VLC player.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Cl Beu
    March 21, 2013 at 4:16 pm
    https://lifehacker.com/5822672/the-best-video-player-for-windows
    Its not the video player that is the issue. The source footage is brightened when its imported into CS6 for some reason…
  • Jeff Pulera
    March 21, 2013 at 5:19 pm
    This suggestion comes from Matrox for users of the MXO2 hardware with CS6, maybe it will help you?
    …on a system that has an NVIDIA display card, use your display card’s control panel to set the dynamic range for video to full. In the NVIDIA Control Panel under Video, select Adjust video color settings. In the displayed dialog box, select With the NVIDIA settings, click the Advanced tab, and from the
    Dynamic range list, select Full (0-255)
    Jeff Pulera
    Safe Harbor Computers
  • Cl Beu
    March 21, 2013 at 5:55 pm
    Hmm, thanks for the response. I tried what you recommended, as I do have an nvidia graphics card, but when I play the clip in Premiere it is still significantly brighter than the same source clip when its played outside of Premiere…
  • Kevin Monahan
    March 21, 2013 at 6:38 pm
    Is it a QuickTime file?
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Cl Beu
    March 21, 2013 at 8:20 pm
    Yeah, it says its a .MOV Quicktime File…
  • Kevin Monahan
    March 22, 2013 at 8:50 pm
    Welcome to QuickTime’s “Gamma Shift.” This article should help you fix this issue: https://www.videocopilot.net/blog/2008/06/fix-quicktime-gamma-shift/
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Cl Beu
    March 27, 2013 at 5:56 am
    Thanks for your help!
  • Cl Beu
    March 27, 2013 at 5:57 am
    Wait, except, this is for a file after its been edited? My problem is that the file looks more washed out in Adobe Premiere, while the gamma is correct outside of Premiere CS6
