Activity Forums Compression Techniques Adobe Premiere CS6
  • Adobe Premiere CS6
    Posted by Chad Mackenzie on October 12, 2014 at 5:16 am
    Hi all,
    A little confused when exporting this video because it looks interlaced and a little blurry. My sequence settings are: DSLR – 1920 x 720 – Square aspect ration
    My export settings are H.264 – Vimeo HD 23.976 – Maximum Render quality.
    Is there anything to do to make the quality look better?
    https://vimeo.com/108689785
    Thanks all
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jeff Pulera replied 11 years, 11 months ago 2 Members · 1 Reply
  • Jeff Pulera
    October 20, 2014 at 1:26 pm
    Is your source 1920×1080 or 1280×720? You said 1920×720 which I assume to be a typo.
    Is the footage natively 23.97?
    If you can post a screen grab of the Export setting panel that will be helpful in troubleshooting.
    Max Render Quality is typically used for SCALING footage – if source and export are the same size, you may not need that turned on.
    Jeff Pulera
    Safe Harbor Computers
