Activity Forums Blackmagic Design Adobe Premiere CS5 won’t capture video upconverted by Blackmagic
  • Adobe Premiere CS5 won’t capture video upconverted by Blackmagic
    Posted by James Brady on July 2, 2010 at 5:43 pm
    I can’t get Premiere CS5 to capture video upconverted through Blackmagic. Here are my steps:
    In the BMD control panel, set input to Y, R-Y, B-Y Video & Analog XLR Audio.
    Next, set input processing to SD to HD (either letterbox or anamorphic) and apply.
    Then in the Adobe Premiere Pro CS5 capture window, select Blackmagic Capture.
    Test any of the HD Standards and formats… I get no input at all.
    But, if I switch to an NTSC SD standard, then I get video input–which shouldn’t happen if it’s being upconverted to HD (at least it didn’t in CS4).
    I downloaded BMD media express–and I can capture upconverted clips there, so it seems that Premiere is simply not understanding the upconversion.
    Maybe I’m missing something… Any ideas are welcome.
    Windows Vista Ultimate 64-bit SP2
    16GB RAM
    Intel Xeon 24GHZ (dual quad-core 3GHZ processors)
    CalDigit 2TB Raid
    NVIDIA Quadro CX v258.49
    Blackmagic Multibridge Pro v7.6.4
    Premiere Pro CS5 v5.0.1
    James Brady
    Senior Editor
    Results Video & Animation
    El Paso, Texas
    http://www.resultsvideo.com
    James Brady replied 16 years, 1 month ago 2 Members · 3 Replies
  • Joshua Helling
    July 2, 2010 at 9:57 pm
    That’s odd. Seems that you have it setup exactly right. You need to make sure that your project is set to the capture format that you ultimately want. So the SD will come in to the board, get converted and should go to premiere as you HD format.
    Can you detail that in an email and send it to our support office support-usa@blackmagic-design.com so that we can reproduce this?
    Please include the system specs above as well as your source specifics and what project settings you have tried that failed.
    Again, if you switch to a SD format and you see input the something is definitely not right.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • James Brady
    July 2, 2010 at 10:20 pm
    Thanks for your prompt response, Joshua. I have already emailed this info and have been contacted by a support engineer.
    The engineer’s first solution was to use BMD’s Media Express to capture. That’s a fine short-term workaround, but I’d like to stay inside Adobe Premiere to do all my logging/capturing.
    I’m just happy to hear someone confirm that it’s not right seeing input on an SD capture when BMD is set to upconvert… at least I know I’m not going crazy!
    James Brady
    Senior Editor
    El Paso, Texas
  • James Brady
    July 21, 2010 at 4:23 pm
    Blackmagic driver v7.7.2 fixed the issue. Thanks, guys!
    James Brady
    Senior Editor
    El Paso, Texas
