Activity Forums Adobe Premiere Pro adobe premiere cs5 footage problem
  • adobe premiere cs5 footage problem
    Posted by Romel Mebane on January 4, 2011 at 1:13 am
    I have an introduction a friend of mine created for me. My sequence is 29.976 but the introduction sequence is 25.00fps. When i play it in my time line, it shows in the source and record monitor about half the size as the monitor. Im trying to make it fit to size as the same size as the monitor. How do i go about doing that?
    Romel Mebane replied 15 years, 8 months ago 3 Members · 4 Replies
  • Romel Mebane
    January 4, 2011 at 1:35 am
    I forgot to make a significant point. I also have an introduction that i created myself and the frame rate i created it in is 29.976. And that is also playing the same way as the footage 25.00fps. Can someone help.
  • David Dobson
    January 4, 2011 at 3:38 am
    What are the frame sizes of your video?
    Frame rates don’t help in this case.
  • Jeff Pulera
    January 4, 2011 at 3:20 pm
    Right-click the clip on the timeline and check “Scale to Frame Size”. Doesn’t fix the frame rate mismatch, but should fill the screen at least.
    Jeff Pulera
    Safe Harbor Computers
  • Romel Mebane
    January 5, 2011 at 12:34 am
    Thanks a lot jeff, i did exactly what you recommended and it worked. i really appreciate your help and the help of others. Creative cow is really an awesome website.
