Activity Forums Adobe Premiere Pro Adobe Premiere CS4 video interpertation problem
  • Adobe Premiere CS4 video interpertation problem
    Posted by Izzy Traub on June 11, 2009 at 5:54 am
    I imported a Mpeg file into Premiere. Everything looks ok, accept the audio did not match up with the video. I played it in After Effects to see if it was just Premiere, but the audio was not matching up in After Effects either. So i checked it in Windows Media Player, and the audio matched up perfectly.
    Any help solving this problem would be greatly appreciated.
    -Izzy
    Rob Shannon replied 17 years ago 3 Members · 5 Replies
  • Eddie Lotter
    June 11, 2009 at 1:06 pm
  • Izzy Traub
    June 12, 2009 at 3:03 am
    Thanks Eddie,
    the only problem is, is that i have been working with MPEG, for about 7 months now, but just now this is the very first clip that has ever done this, infact it used to work, but all of a sudden it doesn’t.
  • Eddie Lotter
    June 12, 2009 at 1:20 pm
    That is indeed strange.
    If you create a new project can you successfully import and use one of the problem MPEG files?
    Cheers
    Eddie
  • Izzy Traub
    June 13, 2009 at 11:56 pm
    I can successfully import the Mpeg file, and use it, but the audio is still off.
    cheers
    -Izzy
  • Rob Shannon
    August 31, 2009 at 11:31 am
    I have impoted my EXCAM fottage on CS3 and it works fine, but CS4 wont play
    any of it back frok the bin or the timeline, the still frame images are up and the little view box shows image but none play and all go to black, can any one suggest any help as adobe dont care!
    Rob
