Activity Forums Adobe Premiere Pro Adobe Premiere CS4 Exporting HD Issues
  • Adobe Premiere CS4 Exporting HD Issues
    Posted by Fraser Coull on November 8, 2009 at 11:14 pm
    Hello,
    I’m at my wits-end completely here.
    I have edited a short film, 7 minutes long, in Adobe Premiere Pro CS4. The footage was shot on a Sony WEX3, HD, with the video files being mp4.
    When I try to export it as either an AVI, a WMV or an MPEG, it only transcodes so far and eventually just pauses and then crashes.
    Does anybody have any suggestions for me?
    Here is my PC specs:
    Windows Vista Home Premium
    Service Pack 1
    Processor: AMD Phenom 9550 Quad-Core Processor 2.20GHz
    Memory (Ram): 4.00 GB
    System Type: 32-bit operating system
    Thank you.
    Bob Dix replied 16 years, 9 months ago 5 Members · 9 Replies
  • 9 Replies
  • Danny Winn
    November 9, 2009 at 4:45 am
    Hey Fraser,
    I’m a little confused, you say the files are mp4’s? Were they captured by Premiere Pro? I thought PPro only captured MPEG2’s for HD.
    I always export my HD projects as MPEG2 with the HDTV1080 Progressive (Match your frame rate) preset. I love the results. A 7 minute HD .AVI film would be an ungodly huge file size, I would never even try it. Try the MPEG2 with either the Full HD (As above) or regular HD preset(HD 720)and see if that make any difference.
    Hope this helps.
  • Fraser Coull
    November 9, 2009 at 10:01 am
    I imported the mp4 files into adobe premiere CS4 and they imported just fine.
    I plugged the camera into my PC via USB and copied the video files across to the hard drive.
    I’ll try the settings you suggest,
    Cheers
    Fraser
  • Brian Louis
    November 9, 2009 at 11:54 am
    [Fraser Coull] “it only transcodes so far and eventually just pauses and then crashes.”
    When you say so far, how far is that? right at the begining? midway? toward the end?
  • Fraser Coull
    November 9, 2009 at 12:38 pm
    It’s about midway.
    Funnily enough last night I tried the dynamic link and sent the sequence straight to adobe encore and it worked fine after a while, but it still doesn’t seem to want to export as an avi, or an mpg2 etc to my desktop.
    Any thoughts?
  • Jon Barrie
    November 10, 2009 at 4:51 am
    If it stalls around the same spot, there might be a particular file that’s corrupt and won’t render. Jpg files will create some problems if they are too big. See if you can narrow down an area inthe timeline that might be a corrupted file and unlink those clips without deleting them. Then choose replace to link them again.
    -Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Bob Dix
    November 11, 2009 at 11:13 pm
    I agree with Jon, check the obvious, defragment, restart the computer as well do a “C” drive check for errors, it has worked for us.
    good luck
  • Bob Dix
    November 12, 2009 at 11:44 pm
    I would try disabling the Automatic Save Option in the Properties Section,Ie., for all projects as it has a tendency to stop Exporting at times, there have been issues there
  • Bob Dix
    November 12, 2009 at 11:49 pm
    Ps. i would disable “Auto Save” during editing on the timeline as well.
  • Bob Dix
    November 12, 2009 at 11:50 pm
