Activity › Forums › Adobe Premiere Pro › Adobe Premiere CS3 Project Setting for huffyuv video file ?
  • Adobe Premiere CS3 Project Setting for huffyuv video file ?
    Posted by Reko Tomo on April 26, 2014 at 8:08 am
    I have AVCHD .mts file (1920×1080 25fps UFF) and convert the file with ffmpeg with the command line as follow :
    for %%a in ("*.mts") do ffmpeg -i %%a -vcodec huffyuv -s 720x576 -acodec pcm_s16le %%~na.avi
    From CS3, I choose the project setting to custom desktop and set as the picture below :
    Import the converted file to CS3 then drop it in the timeline.
    But the timeline show a red line which means when I hit ENTER to preview my editing, Premiere will re-render the whole file in the timeline.
    I’m hoping that Premiere won’t re-render the whole file but only the portion that has an effect or transition just as when I work on DV file with default DV-PAL project setting when hit ENTER to preview.
    How do I set CS3 project setting to avoid this ?
    Or maybe I didn’t do a correct way with the ffmpeg command line that I wrote when convert the .mts file to huffyuv avi ?
    Any kind of respond would be greatly appreciated.
    Thank you in advanced.
    regards.
    Ann Bens replied 12 years, 4 months ago 2 Members · 2 Replies
  • Ann Bens
    April 26, 2014 at 12:45 pm
    Your pixel aspect ratio is set to 4:3, should that not be set to widescreen?
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Reko Tomo
    May 10, 2014 at 4:33 am
    Hi Ann…
    I’m sorry for the delay.
    Thank you very much for your respond and correction.
    ffmpeg command :
    for %%a in ("*.mts") do ffmpeg -i %%a -vcodec huffyuv -s 720x576 -aspect 16:9 -acodec pcm_s16le %%~na.avi
    Here is the spec of the generated AVI file :
    Video
    Format : Huffman
    Codec ID : HFYU
    Duration : 48s 960ms
    Bit rate : 87.2 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 8.407
    Stream size : 509 MiB (98%)
    When I put the file in Premiere Project with 16:9 setting, Premiere still “thinking” that this generated file is 4:3 … not 16:9.
    I put the file to the timeline, and the monitor show the image with a black bar on the left and right side.
    So I did this :
    The monitor now show the image correctly,
    BUT – the red thin line on the timeline still there :(.
    What am I doing wrong ?
    (scratch my head and pull my hair)
    Thank you once again for your respond, Ann.
    regards,
    reko
