Activity › Forums › Adobe Premiere Pro › Adobe Premiere CS3 Multi Cam Edit issue
  • Adobe Premiere CS3 Multi Cam Edit issue
    Posted by Andrew Daley on July 8, 2009 at 7:36 am
    Hi All,
    Just having a slight issue that i can’t resolve myself with multi camera mode.
    When i do all it says and move to the new sequence to multi camera edit, everything works fine except….
    Whichever video i had in first, the audio always stays with that video when i switch between them.
    Example. Multi camera mode, Video A runs, i then switch to Video B, but the audio from A is still running.
    I have tried all i can with the “mixing the audio” stuff in the tutorials and help, but i can’t seem to work it out.
    Could it be something simple i am missing?
    Any help is greatly appreciated.
    Andrew
    Jack Laurie replied 17 years, 2 months ago 3 Members · 3 Replies
  • Mike Velte
    July 8, 2009 at 10:48 am
    In the upper right corner of the Multicam window is a wing menu…choose “Audio Follows video”
  • Andrew Daley
    July 8, 2009 at 12:35 pm
    Hi Mike,
    Thanks for that, i had tried that in the past, and it didn’t make a difference.
    i have though in the past little while found the answer. It was as simple as pressing enter and rendering the audio.
    I find it amazing that Adobe write a bit essay in their help file about Multi Cam editing and getting the audio right, when it can be summed up as easy as, “before you start, press enter…..”
    Thanks anyway for the input
    Andrew
  • Jack Laurie
    July 17, 2009 at 11:47 pm
    I found that when multicam enabled, only the first track comes over. When I’m done mixing the 2 audio tracks in the source sequence all I have to do is ‘un’ enable multicam in the multicam sequence and export the movie. both tracks are there mixed as I wanted. Didn’t render first.
