Activity Forums Adobe Premiere Pro Adobe Premiere CS 5 DVCPRO 30p sequence settings?
  • Adobe Premiere CS 5 DVCPRO 30p sequence settings?
    Posted by John Johnston on February 19, 2014 at 5:15 pm
    Hi!
    Just shot a project on DVCPROHD 720p30 and found no sequence setting in Premiere that matched.
    Should I use the DVCPROHD 720p60?
    John Johnston replied 12 years, 7 months ago 2 Members · 2 Replies
  • Jon Doughtie
    February 20, 2014 at 2:12 pm
    You could start with that setting and revise it, making a custom one for you.
  • John Johnston
    February 20, 2014 at 4:52 pm
    Hi and thank you for your reply. I saw the custom option but it is grey’d out…is there a trick to that? Because it makes me nervous having double the frames in my sequence.
    I just took a look in FCP and when i selected DVCPROHD 720p30 as my sequence setting then imported my footage into the timeline FC changed it to the native compression @ DVCPROHD 720p60. When I forced it to stay at 720p30 it required rendering; so maybe that is why Adobe doesn’t have that setting.
    Anyhow I am committed to Premiere now and hopefully it will not have any quality issues…
    Thanks again for your reply!
