Activity Forums Adobe Premiere Pro Adobe Premiere and a computer to support it
  • Adobe Premiere and a computer to support it
    Posted by Chixwithtrix on September 5, 2006 at 4:27 pm
    I don’t know if this is the right forum, if it isn’t please point me in the right direction :).
    I’m into video editing as a hobby at the moment and am going to school to make it a profession. I have an old Pentium 4 2.4ghz processor and 512mb of ram…etc that refuses to render anything in Adobe Premiere Pro. I know it at least needs more RAM to function, but my multitasking suffers as well from Premiere to After Effects, etc so I figgured the best way would be to start over with newer technology that would last me longer than upgrading this older machine.
    Needless to say I want to upgrade
    I have $1200 for processor(s), mobo, RAM, and video card. (I can upgrade the RAM and vid card at a later date though). When I went on NewEgg I and looked around at Intel Xeon processors This is the one I was looking at: https://www.newegg.com/Product/Product.asp?Item=N82E16819117075
    -I am assuming that Xeon’s are only for dual processor applications?
    -The only boards I could find for them were server boards. What exactly are server boards?
    -Would this processor work well for a video machine? Are Xeons good for normal use (not server)?
    The Xeon seemed to have what I was looking for, but I don’t know if it would work or there were better things out there…?
    Another Processor I was looking at was this one: https://www.newegg.com/Product/Product.asp?Item=N82E16819116240
    -Is it any good for a video editing application?
    I apologize if this is the wrong forum, but hope that sommeone can help me out. Thanks
    John Baum replied 19 years, 12 months ago 3 Members · 5 Replies
  • Alex Jusay
    September 5, 2006 at 5:18 pm
    Hey, I have successfully installed Premiere Pro on a dual PIII 733Mhz with 512Mb ram (before installing it on our office workstation) for testing, and it worked flawlessly. It was fast and there was no lag. We were able to finish a lot of projects without any problems. It made us wonder why we bought a killer machine for premiere pro–until of course we added effects. Unfortunately, Premiere Pro 2 would not install on that dual P3 coz it was looking for a specific CPU instruction. My suggestion is to go to VAR sites and check out their specs.
  • John Baum
    September 5, 2006 at 5:41 pm
    Basically for video get as fast as you can afford. Any type will work fine. Though the Xeons usually have a larger cache which does help encoding and rendering speeds a bit.
    You should check out the new Core 2 Duo chips. They are currently the fastest chips you can get and not too expensive. And don’t let the lower clock speeds fool you. They are designed differently then previous intel chips so even though they have a lower clock speed they are still faster.
    The more RAM you have the faster and smoother your video app will run. Hard drive capacity and speed are also very important. At the very least you should have a seperate drive just for your media files.
  • Chixwithtrix
    September 5, 2006 at 11:34 pm
    alright, thanks for the replies (I’ve had no others on other foums :()
    So, I still do not understand the Xeons being server processors…what makes a server machine different from a normal home machine (more expensive, more power capability?)? What is the differene between a server board and a normal board?
    thanks!
  • Alex Jusay
    September 6, 2006 at 4:35 am
    I agree with ghobii, get the Core Duo. Xeons, besides having a larger cache, also has several CPU instructions and extensions ideal for server operations (aka background task). If you search hard enough, you’ll find XEON Premiere users NOT noticing a big difference in performance than their counterparts. I used to work in an HP XW series Avid Adrenaline machine with the dual Xeon and it was really fast, although we cant really tell if its the xeons or the Adrenaline hardware plus the RAID setup.
  • John Baum
    September 6, 2006 at 5:17 pm
    Server hardware in general is more robust. Higher quality components since servers generally need to run 24/7 with a high degree of reliability. They may also contain extra components that allow redundant power supplies, high speed disk arrays, optimised I/O…there is nothing on them that would make them a bad choice for video editing. Quite the opposite. But unless you are in a very busy work enviorment where your workstation is busy all day everyday you may be paying for more then you need.
