Activity Forums Adobe Premiere Pro Adobe Premiere – Alpha not working
  • Adobe Premiere – Alpha not working
    Posted by Jon Gagnon on December 5, 2012 at 7:08 pm
    I have some graphics that were exported from AE that have Alpha channels. They look fine in Premiere until the clips get rendered. Once rendered what should be transparent is grey. I have checked the clip settings and the “ignore alpha channels” box is unchecked.
    Any ideas?
    Jon
    Jon Gagnon replied 13 years, 9 months ago 2 Members · 2 Replies
  • Jeff Pulera
    December 5, 2012 at 10:10 pm
    Hi Jon,
    Folks have been having strange issues with transparency and such…try disabling the Mercury Playback Hardware (if applicable) and render a test that way once and see if it helps
    Jeff Pulera
    Safe Harbor Computers
  • Jon Gagnon
    December 5, 2012 at 10:55 pm
    How do I do that?
    I have a friend who says if you update Premiere is isn’t an issue. (at least not for him and his computer) I think I had this problem before and simply re-exported from AE with NONE as compression.
    Thanks for your help,
    Jon
