Activity Forums Adobe After Effects Adobe Premiere & After Effects CS3 won’t open
  • Adobe Premiere & After Effects CS3 won’t open
    Posted by Jaeson Jrakman on August 1, 2012 at 3:09 pm
    So here’s my system specs:
    ecsOperating System System Model
    Windows XP Home Edition Service Pack 3 (build 2600)
    Install Language: English (United States)
    System Locale: English (United States) Intel Corporation
    Enclosure Type: Desktop
    Processor a Main Circuit Board b
    2.67 gigahertz Intel Core2 Quad Q9400
    64 kilobyte primary memory cache
    3072 kilobyte secondary memory cache
    64-bit ready
    Multi-core (4 total)
    Not hyper-threaded Board: Intel Corporation DG31PR AAD97573-304
    Serial Number: BTPR90800SZ8
    Bus Clock: 1333 megahertz
    BIOS: Intel Corp. PRG3110H.86A.0064.2009.0212.1149 02/12/2009
    Drives Memory Modules c,d
    2165.09 Gigabytes Usable Hard Drive Capacity
    1141.70 Gigabytes Hard Drive Free Space
    ATAPI iHAS322 8 [CD-ROM drive]
    LITE-ON DVDRW SOHW-1673S [CD-ROM drive]
    Generic USB CF Reader USB Device [Hard drive] — drive 3
    Generic USB MS Reader USB Device [Hard drive] — drive 5
    Generic USB SD Reader USB Device [Hard drive] — drive 2
    Generic USB SM Reader USB Device [Hard drive] — drive 4
    HDT722516DLAT80 [Hard drive] (164.70 GB) — drive 0, s/n VD071BTCCUAK3E, rev V43OA70A, SMART Status: Healthy
    ST2000DL001-9VT156 [Hard drive] (2000.40 GB) — drive 1, SMART Status: Healthy
    3326 Megabytes Usable Installed Memory
    Slot ‘J6H1’ has 2048 MB
    Slot ‘J6H2’ has 2048 MB
    Local Drive Volumes
    c: (NTFS on drive 1) 2000.40 GB 996.80 GB free
    d: (NTFS on drive 0) 164.69 GB 144.90 GB free
    Network Drives
    None detected
    Users (mouse over user name for details) Printers
    local user accounts last logon
    Owner 9/15/2011 4:24:52 PM (admin)
    UpdatusUser 9/15/2011 4:26:07 PM
    local system accounts
    Administrator never (admin)
    ASPNET never
    Guest never
    HelpAssistant never
    SUPPORT_388945a0 never
    Marks a disabled account; Marks a locked account Adobe PDF Converter on My Documents\*.pdf
    CAPTURE FAX BVRP on NUL:
    Lexmark X1100 Series on USB001
    Microsoft XPS Document Writer on XPSPort:
    Send To Microsoft OneNote Driver on Send To Microsoft OneNote Port:
    Controllers Display
    Standard floppy disk controller
    Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers – 27DF
    Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller – 27C0
    Primary IDE Channel [Controller] (2x)
    Secondary IDE Channel [Controller] NVIDIA GeForce 9500 GT [Display adapter]
    Acer V223W [Monitor] (22.0″vis, s/n LBQ0C11440A5, October 2009)
    Acer V223W [Monitor] (22.0″vis, s/n LC3080114265, March 2009)
    Not sure what other information that you might need other than I’m running Adobe Premiere Pro and After Effects CS3.
    I’m having a serious problem getting these programs to open.
    They were working just fine, but I made the mistake of installing Format Factor 2.96 and Any Video Converter.
    When I installed Format Factory, it hung on something called ffdshow.ax for some time.
    Format Factory starts up just fine.
    But when I try to start up Premiere or After Effects, before the program gets a chance to open it says that it has encountered a problem and needs to close.
    There is a small link that says “to see what data this error report contains click here”
    When I click there and view the error report, it states that the Error Signature is this:
    AppName: adobe premiere pro.exe AppVer: 3.2.0.0 ModName: ffdshow.ax
    ModVer: 1.1.4212.0 Offset: 001b71f6
    The same thing happens when Adobe After Effects is opened.
    There is another window of information that says, “The following information about your process will be reported” but I can’t copy any of the information in there for some reason.
    I looked through the Premiere files and can’t find the ffdshow.ax anywhere. I’ve also tried searching for it in my computer and came up empty handed.
    I’ve tried to re install Format Factory 2.90 thinking maybe it might correct the problem that 2.96 seemed to create, same thing.
    I’ve tried rebooting the computer several times, same thing.
    Any help that anyone could give would be greatly appreciated!
    Jaeson Jrakman replied 14 years ago 43,595 Members · 1 Reply
