Activity › Forums › Adobe Premiere Pro › adobe premiere 6.5 whis mxtor rtx100
Posted by Amir Shachar on September 25, 2005 at 5:46 pmhi
i have Adobe Premiere 6.5 whis MTROX RTX 100.
and whan i open the Premiere i have the foling masege:https://planet.nana.co.il/00723/Premiere.jpg
and becas of thet my Premiere does not woork whis the Matrox
what i have to do?…..
thenxs
amirAndre Gagnon replied 20 years, 11 months ago 5 Members · 4 Replies -
Aanarav Sareen
September 25, 2005 at 7:49 pmLooking at the error code, it appears as if the error is related to the Maxtor card and not Premiere. Call Maxtor and see if they can help you.
Aanarav Sareen
Adobe Certfied Expert, Premiere Pro
https://www.asvideoproductions.com/video -
Jim Arcon
September 26, 2005 at 4:43 amIts not just you…. I also get this same message whenever I open one program that uses the RTX100, close that program, then open another. For instance, if I use the RTX with AE, close AE and open PPro, I get the message. I have to shut down between using the different programs if I want to see them display on my NTSC monitor.
Shouldn’t be that way, but it is on my Dell8400 with 3.4ghz and WinXP Pro. My guess is that Matrox is not releasing something when the program closes
Jack Pfeiffer
September 27, 2005 at 1:40 pmHello All..
For the record, the Matrox RTx100 card is designed
to work with legal copies of ADOBE PREMIERE PRO v1 & v1.5 ONLY.The Matrox RTx100 will NOT work Premiere V6.5 or lower.
If you had the simple read-me notes, you would know this..
You may NOT post questions about using illegal software at the Creative cow forum.
Jack Pfeiffer
Author: “Combustion v2: The WebWarriors On-Line Guide”
Co-Host: CreativeCOW Combustion/Edit Forums -
Andre Gagnon
September 27, 2005 at 8:17 pm[Jack Pfeiffer] “The Matrox RTx100 will NOT work Premiere V6.5 or lower”
That statement is misleading.
I have personaly used the RT.X100 with Premiere 6.5 during more than a year and thousands of users are still using it.
Have a look at this Matrox link that leads to the downloading of the drivers required by Premiere 6.5 (that is ver. 4263)
https://www.matrox.com/video/support/rtx100xtremepro/software/home.cfm
This is a short extract from that page:
Matrox X.tools for use with Adobe Premiere 6.5
Downloadable software updates, utilities and documentation for X.tools build 4263 for use with Adobe Premiere 6.5.
Note that Premiere Pro 1.0 and 1.5 each require their own version of the drivers, ver. 5078 and 6122 respectively.
