Activity › Forums › Adobe Premiere Pro › Adobe Premiere 2015 lagging?!?!
Posted by Richard Lutz on June 19, 2015 at 4:17 amI just updated to the latest version of Premiere and I’m experiencing lots of lagging. I have a 2013 MBP and I’m working on a project that is running GH4 footage. Does anybody have any ideas?
Clover Carroll replied 10 years, 4 months ago 4 Members · 3 Replies -
Jake Cauty
June 20, 2015 at 12:30 amIrritating. Things i’d do: Set playback resolution to lower quality (bottom right menu in playback window).. do a PRAM reset..(hold cmd, alt, p, r on startup, atlas 4 times) Clear media cache in premiere pro (premiere, preferences i think)
Cant think of any others, it may not like it if your sequence settings aren’t right, but shouldn’t affect too much.. Best of luck
Michael Ron
June 22, 2015 at 7:37 amAre you working on a project you started on PP CC14, or is it a new project created in CC15?
Is your project using any special effects, plug-ins etc? And did you make sure the sequence settings match the source footage?Try clearing your media cache manually:
1. inside PP navigate to Preferences > Media to see where your cache and cache database are saved
2. quit Premiere and navigate to these folders in the finder
3. delete all the files, relaunch PP and let it recreate the cache files.Also, what graphic card do you have? Do you have the CUDA drivers installed? Are you using GPU acceleration at all (CUDA / Open CL)? And if you are, what happens if you switch to software-only?
Some people have reported CUDA issues after updating to CC15, but removing cache and updating the drivers worked for most. -
Clover Carroll
May 17, 2016 at 9:12 pm
