Activity Forums Adobe Premiere Pro Adobe Premier Pro v.7
  • Adobe Premier Pro v.7
    Posted by Harold12 on August 30, 2006 at 7:15 pm
    I have burnt many DVD’s using Adobe Premier Pro v.7 but recently before burning to DVD Adobe premier Pro returns the following error and ejects the DVD from the computer.
    Could not complete the last command because: DVD err (DVDErr, -224
    Can anyone help
    Harold12 replied 20 years ago 5 Members · 8 Replies
  • 8 Replies
  • Aanarav Sareen
    August 30, 2006 at 8:06 pm
    How much space do you have on your C: drive? Does this project differ in any way from prior projects? What happens if you try to open a previous project and export that to DVD?
  • Xavier De champs
    August 30, 2006 at 8:13 pm
    Had this error too. Seemed to work a little bit, when I shut a lot of programs off, which where running in the background. Used a freeware-tool to shut them down. But still, often it didn
  • Harold12
    August 31, 2006 at 8:06 am
    Nothing has changed on drive, over 150GB free. Is there any update or patch that can be downloaded to correct this error
  • Harold12
    August 31, 2006 at 8:08 am
    150GB free, nothing has changed. Is there any update or patch for this error?
  • Greg Beckt
    August 31, 2006 at 3:10 pm
    You might try nesting your comp and then burning your DVD from the new comp. I’ve had this happen on occasion and that workaround has done the trick.
    Greg
  • Aanarav Sareen
    August 31, 2006 at 10:59 pm
    [harold12] “150GB free, nothing has changed. Is there any update or patch for this error?”
    A software company, such as Adobe wouldn’t create patches for errors such as these. Let me look around and see if there is any other mention of this error.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Blast1
    September 1, 2006 at 4:35 am
    How large is the file you are trying to put on the DVD? You don’t want to try to use all available space, leave a bit of wriggle room.
  • Harold12
    September 1, 2006 at 7:01 pm
    Problem solved. I now use Adobe Premier to edit the footage and then I export to the hard drive and then load it to Sony Architect and Sony Archtiect burns it without any errors or any problems and of a very high quality too. I know it is expensive but Premier always seems to have these sorts of problems as with Architect problem free.
