Activity Forums Adobe Premiere Pro Adobe Premier Pro CS4 won’t render
  • Adobe Premier Pro CS4 won’t render
    Posted by Boris Isakov on July 17, 2009 at 12:16 am
    I put in a clip into the timeline on Abobe Premier Pro CS4. The red bar appears on the top. So I render it and it starts processing. BUt after it is done rendering the red bar is still their and the clip in the timeline still acts like it’s un-rendered.
    Any suggestions?
    Boris Isakov replied 17 years, 1 month ago 2 Members · 2 Replies
  • Mike Velte
    July 17, 2009 at 10:28 am
    What are your sequence settings? What are the properties of the video?
  • Boris Isakov
    July 18, 2009 at 2:27 am
    now it does not even complete the render. The render que freezes and crashes premier pro. THe files are .MTS. and my sequence setting are,
    Editing mode: AVCHD 1080p pixel
    timebase 23.976 frames/second
    VIDEO
    Frame size: 1920 horizontal 1080 vertical 16:9
    Pixel: Aspect ratio Square pixels (1.0)
    Field: no fields (progressive scan
    Display Format: 24fps Timecode
    AUDIO
    Sample rate: 48000 Hz
    Display Format: Audio Samples
    VIDEO PREVIEWS
    Preview File Format: I-Frame Only MPEG
    Codec: MPEG I-Frame
    Maximum Bit depth — UNCHECKED
