Activity › Forums › Adobe Premiere Pro › Adobe Premier Pro CS3 crashing my system randomly. why?
  • Adobe Premier Pro CS3 crashing my system randomly. why?
    Posted by Jeremy Chopra on March 28, 2010 at 3:48 pm
    Hi everyone,
    I have a strange problem regarding Adobe Premier Pro CS3. Completely randomly it seems to crash my system whilst I’m editing.
    Below are my system specs.
    I’ve never seen this type of problem before on any other computer I’ve used so am lost as to what the problem could be.
    The crash itself is odd. it happens completely randomly while i’m using it with the whole screen going black NOT blue and the sound blows out, but the computer remains on and the only way to shut down is to unplug directly from the mains and restart as there is no other way to gain access to the computer once this happens. Even if I switch the monitor on and off.
    Does anyone know what the problem might be? and why it would be so random? I know the sound card is not very good – Onboard RealTek HD audio. It does not allow capture of sound with any adobe products but everything seems to work fine otherwise. I capture the footage via another system and use this one to edit as it has more Ram but this crashing happens everytime and at random points.. there is just no warning. It only crashes as I’m using it and not if its on but not in use..
    System Specs:
    HP s5229uk
    AMD Athlon(tm) IIx4 620 Processor (2.6GHz)
    4GB Ram
    Windows 7 (64bit)
    NVIDIA GeForce G210 (Graphics card)
    Thanks in advance for any help you can give.
    Jeremy Chopra replied 16 years, 2 months ago 4 Members · 5 Replies
  • Vince Becquiot
    March 28, 2010 at 4:46 pm
    Hi Jeremy,
    That black screen sounds like your Nvidia card is overheating, or running on low power (less likely). Check to see if you have another card below or above obstructing its fan flow, or increase the overall case fan speed.
    Not sure if there are LEDs showing you the fault on that particular card, but crack open the case when that happens to see if any of them light up on the card itself, then look at the manual for diagnostic.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Brian Louis
    March 29, 2010 at 12:30 am
    Vince may have something about the fan, there is a fan speed problem with certain drivers, check this site below
    https://www.nvidia.com/Download/index.aspx?lang=en-us
  • Tim Kolb
    March 29, 2010 at 2:51 pm
    The sound blowing out is an interesting symptom…
    I know there have been audio cards over the years whose malfeasance transcends sound in certain configurations.
    After you check on the heat issue (there is a particular issue with a certain driver set for NVIDIA that doesn’t seem to throttle up the fan when needed), you might want to simply internet search your sound card and Premiere Pro and see if there are any similar complaints…
    I’m not familiar with NVIDIA gamer cards in general, but the model you specify is definitely at the bottom end of the product line. I don’t think it’s out of the question that it just may be stretched a bit too far…
    TimK,
    Director, Consultant
    Kolb Productions,
  • Jeremy Chopra
    April 4, 2010 at 12:39 pm
    Sorry for replying late to everyone. thanks for the info. I’m just editing on my laptop for now to get the project done before i can make time to properely try out the hardware check and driver you guys recommended trying. The other interesting thing I didn’t mention though is that with premier I get the issues but NOT with after effects! It seems strange that the issue would occur on the less powerful premier and not after effects? There’s nothing wrong with the software I isntalled (as in not corrupted or anything) as its the same package installed on my laptop and I even re-installed on the desktop.
    I’m really hoping though that the driver solves it as the desktop is a slim design and replacing the graphics card to something better is going to be a problem in terms of simply getting on to fit the body 🙁
    The sound card is definitely poor as is onboard and doesn’t capture sound at all.. plays sound without a problem and sounds very good in fact but is not ASIO compatible. I thus intended to capture via my trusty laptop onto an external drive and then planned to edit from that hard drive onto desktop…
    Anyone think that maybe the problem is the sound card and not the graphics card? as seems the only difference that would make it crap out on premier and not after effects which doesn’t run sound except when rendering?
  • Jeremy Chopra
    July 8, 2010 at 9:33 am
    Just an update on this issue in case anyone else has the same issue, it WAS the sound issue and not the graphics card. ASIOS is required for premiere and realtek onboard sound isn’t up to it so unfortunately although everything else runs perfect if you have a non ASIOS sound card your sustem will crash everytime, albeit suddenly! So yes, a sound card hardward upgrade or possibly entire system upgrade seems in order.
