Activity Forums Adobe Premiere Pro adobe premier pro broadcast clock
  • Blast1
    October 9, 2006 at 6:21 pm
    Its called an “Acadamy Leader”, if using Ppro 2, the instructions are on P186 of your manual, Its in the index as “Leader, Counting”, same in earlier ver of Ppro.
  • Glenn Maguire
    October 10, 2006 at 10:42 am
    Hi Thanks for the reply, although what you’ve mentioned isn’t a broadcast clock its a count in leader. The clock we need looks like an old analogue clock and counts in from 45 seconds and contains all the advert details that the BACC require.
    Glenn
  • Blast1
    October 10, 2006 at 11:57 am
    [Hedpuk] “BACC”
    You are in the UK, I think time standard when Broadcast Clock or a program flow pie chart, I’ve seen something like you are refering to, but they were a template made in a program like AFX or Boris, have you tried a net search?
  • Glenn Maguire
    October 10, 2006 at 4:42 pm
    Hi. Thanks for the info. Managed to get the clock on tape but it means editing it. What version of boris do you think had it in, i have a copy of one of them some where.
    I tried a net search too with no luck at all, the only thing that seems to generate it is the avid system.
    Glenn
  • Blast1
    October 10, 2006 at 6:09 pm
    [Hedpuk] “What version of boris do you think had it in, i have a copy of one of them some where.”
    It didn’t come with the program, but was made with it, talking to a friend(owns a mac) he said he got one from the internet while he was in the UK.
    BACC(his defination of the acronym suppressed)
