Activity › Forums › Adobe Premiere Pro › Adobe premier cs6 and canon t5i
Posted by Jonn Gibson on December 29, 2016 at 8:03 amHow do i import footage, what’s the best codecs to edit with? Do I need to create proxy?
Ayan Banerjee replied 9 years, 8 months ago 4 Members · 8 Replies -
Andy Patterson
December 29, 2016 at 11:38 amIs it Camera RAW or JPEG? JPEG should work as is? I don’t know if Premiere can take Camera RAW files from a Canon Camera. If it doesn’t make a feature request.
Jonn Gibson
December 29, 2016 at 1:45 pmI would be for video, I beleave the camera shoots QuickTime. It’s the canon 5ti.
Jeff Pulera
December 29, 2016 at 2:34 pmHi John,
You should be able to edit the clips natively. For best chance of success, follow these steps:
Copy ENTIRE contents of SD card to a NEW folder on your hard drive. Don’t copy just the video clips – copy everything over. There is metadata in the folder structure that Premiere needs. In Premiere, import using Media Browser, rather than File > Import.
Jeff Pulera
Safe Harbor Computers -
Jonn Gibson
December 29, 2016 at 2:46 pmThe files are shot in quick time. I’m working in windows 10. I don’t see any QuickTime on premier. I will look again.
Jeff Pulera
December 29, 2016 at 3:15 pmAre you looking for a Sequence Preset for QuickTime perhaps? Doesn’t exist. What you want is a preset that matches the footage, meaning frame size, frame rate, pixel aspect, fields.
Import your clips. In Project Bin, right-click a clip and select New Sequence from Clip. Or drag clip onto New Item button. Or dropping a clip into an empty timeline sequence, it should ask if you want to change sequence to match the clip. Any of those methods will yield same result.
Jeff Pulera
Jonn Gibson
December 29, 2016 at 3:37 pmI just looked around the net and found out that the QuickTime footage would have to be transferred to mp4 or something else becuase premiere cs6 on windows does not support QuickTime. Did anyone experience this? I’m trying to make a decision on a camera to shoot footage and edit in cs6.
Andy Patterson
December 29, 2016 at 5:19 pmWill changing just the file extension work? It worked for a Canon Camcorder in the video link below.
Ayan Banerjee
January 12, 2017 at 6:29 pmYou do not need to change the extension, but need to install Quicktime. Otherwise neither will premiere import mov files, nor will you see Quicktime export options in media encoder.
