Activity › Forums › Adobe Premiere Pro › Adobe Premier CC 2014 and Flickering
Cali Pvp replied 10 years, 10 months ago 11 Members · 14 Replies
Grzegorz Kwiatkowski
July 7, 2015 at 5:43 amI’ve had this issue in my production company since upgrading to CC 2014 mostly using Magic Bullet Looks on adjustment layer. The flickering can appear on any clip affected by adjustment layer with MBullet- no pattern, no rule. Magic Bullet suite was an important element of our workflow but it just became impossible to use it normally. Maybe CC 2015 is free of this bug? Anybody tried?
Aaron Weiss
July 21, 2015 at 5:52 pmThat thread seems to be dead now, but on my project (involving high res stills on a 2014 15″ Retina MBP), the flickering happened only using the OpenCL renderer. It’s fixed by switching to either the CUDA or the software renderer.
This looks like the kind of issue where YMMV, so throw a lot of spaghetti against the wall and see what sticks.
Catalin Buda
August 12, 2015 at 2:07 amUnfortunately, CC 2015 also has this bug!, but, so far, I experienced it only when I had an adjustment layer containing the following effects: Lumetri Color, Color Balance, Color Balance (HSL) and the Tri Way Color Corector. I had a lot of others adjustment layers containing the Lumetri Color, the Color Balance and the Color Balance (HSL), but only when I added the TriWay Color Corector I got this flickering issue. Also, the weird thing is that although it was clear the TWCC caused the problem, the flickering disappeared when i turned off the Color Balance and not when I turned off the TWCC.
Cali Pvp
November 20, 2015 at 1:02 amI’m getting the same thing. I was able to export directly for Premiere and not see any flickering.
