Activity Forums Adobe Premiere Pro Adobe Pre. 6.5 dissapearing
  • Adobe Pre. 6.5 dissapearing
    Posted by Andrew Weener on October 4, 2005 at 1:15 pm
    I need help. I have canopus Dv Storm, Premiere 6.5 2 gig Ram, 2.8. Premiere will just vanish for no reason when I am editing, converting to a mp2 etc… Please help me.
    Blast1 replied 20 years, 11 months ago 3 Members · 2 Replies
  • R. Hewitt
    October 4, 2005 at 2:32 pm
    Sounds like the application is crashing or the user interface is being stopped.
    First check to see if Premier is still active by looking at the Application list in Task Manager. If so, see if it will let you switch back to the application by selecting it from the list and clicking Switch To.
    If Premier is not running it is most likely a process or driver that is shutting down the main application service.
    Has something been recently installed? Updated?
    If using antivirus software, try stopping it, re-launching Premier and see if the problem repeats.
    For a period I found Norton Antivirus preventing my machine from capturing reliably even though realtime scanning was disabled. As long as Norton isn’t running all works normally.
  • Blast1
    October 4, 2005 at 8:35 pm
    What chipset does your MoBo use? The storm2 with AP6.5 is usually stable.
