Well it depends what you are going to be doing.
DVDA might have fewer bugs, and work better for a real simple menu and quickly slapping your dvd together, however Encore is much better for doing custom menus, transitions, scene selection menus, etc. Also, Encore’s integration with After Effects, Premiere, and Photoshop is extremely beneficial.
If you are curious as to how to fully author a dvd using custom motion menus, transitions, chapter index, and avoid many of the bugs with the program… you should watch our Encore Video Tutorial, available from the tutorial section of our website (select any menu, and then select the Encore tutorial). The tutorial was created for our Pro Motion Menu Kit products, however it is a valuable learning tool for anyone.
Jon Geddes
http://www.precomposed.com
