Activity › Forums › Adobe Premiere Pro › Adobe Multi Drive Plug in?
  • Adobe Multi Drive Plug in?
    Posted by Steve Mac kenzie on November 1, 2006 at 11:24 pm
    My wife was on the phone getting some non tech registration help and the rep said that there is an extra plug in that needs to be used for multi drive applications but I did not see anything on the site… Anyone know about this plug in if it exists and if so, where I can find it?
    Steve
    Steve Mac kenzie replied 19 years, 11 months ago 3 Members · 5 Replies
  • Blast1
    November 2, 2006 at 2:30 am
    What kind of drive, optical, harddisk, etc?
  • Steve Mac kenzie
    November 2, 2006 at 2:50 am
    For Multiple Hard Disk applications.
  • Pablo2099
    November 2, 2006 at 4:27 am
    Im going to take a wild stab in the dark here and am thinking the tech was reffering to adobe applications being installed on a raid system. Their is a well known issue for registration on this set up and its not a plug in – its a patch to fix the problem. You cant download it from anywhere, you need to request it be emailed to you by contacting Adobe support.
    Hoep this helps
    P
  • Blast1
    November 3, 2006 at 12:51 am
    Like mentioned there could be raid problems, easy solution is to run apps from a descrete drive, running apps from a raid is a waste as once that app is loaded there is very little action on the array unless you are also keeping data on it which sometimes can cause other problems.
  • Steve Mac kenzie
    November 3, 2006 at 2:17 pm
    I think the RAID install scenerio makes sense. Thank you everyone for your insight!
