Activity › Forums › Adobe Premiere Pro › Adobe Multi Cam editing on 2 cameras Free Run Time Code
  • Adobe Multi Cam editing on 2 cameras Free Run Time Code
    Posted by Pella Media on September 28, 2006 at 7:45 pm
    I used 2x Panasonic HD cameras filming a football match. I synchronized both cameras to free running time code with a starting time of 15h00 00 00. Both cameramen moved up and down the side of the field shooting on and off as they reposition, so the cameras did not run continually. Edit in Adobe Prem 2. I captured Cam 1 footage to Bin 1 and Cam 2
    Mike Velte replied 20 years ago 3 Members · 2 Replies
  • Alex Udell
    September 29, 2006 at 11:12 am
    There will be no easy way to do this.
    Multicam workflows really only work well when material is shot continuous.
    You could try to create sync between the 2 camera streams by splitting the clips and editing them on to a timeline manually…
    in the end….it will take you so much time just to do that, that you will prbably be just as successful cutting things manually….
    sorry for the bad news…but that’s my assessment…
    Alex
  • Mike Velte
    September 29, 2006 at 11:42 am
    Capturing with ScenalyzerLive using Scene detection will result in a list of clips with the date and time as part of the file name and offer a small help when trying assemble each cam on the timeline. Even with that you have a huge mess.
