Activity Forums Adobe Premiere Pro Adobe Media Encoder wrong presets
  • Adobe Media Encoder wrong presets
    Posted by Mike Sierra on March 26, 2013 at 9:41 pm
    I have a project and I want to add it to the queue.
    I select the sequence, then select File, Export, Media. I define a new preset there called “iphone4”, that is a Quicktime format, MP4 format with custom parameters.
    I then click on Add to queue.
    Adobe Media Encoder opens showing different parameters and ready to encode the video in F4V. The preset I have defined there is not on Adobe Media Encoder. BTW there is no QuickTime option on AME. No way to adjust the same parameters I had there.
    I have reinstalled Premiere 3 times, nothing. How do I solve this?
    Mike Sierra replied 13 years, 5 months ago 2 Members · 2 Replies
  • Ryan Holmes
    March 26, 2013 at 10:26 pm
    Have you tried creating the new preset directly inside of AME? Instead of doing in PPro do it in AME. In the Preset Browser tab click on the “+” and setup from there. Once you’re done, save it and verify it shows up in your list of options.
    Quicktime is available inside of Premiere. Once you create a new preset a dialog box will pop up. Under the Format” drop down menu choose Quicktime (you can also do stills, mp3, wav, etc from here), then choose your codec of choice (DV NTSC, ProRes, DNxHD, Uncompressed, etc.).
    If you’re on a PC make sure that Quicktime is installed on your system.
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
  • Mike Sierra
    March 27, 2013 at 12:44 am
    Thanks Ryan but seconds after posting this I found this https://forums.adobe.com/message/5109553
    The answer is #8 on that page.
    This may help other people with the same problem.
