Activity Forums Adobe Premiere Pro Adobe Media Encoder – Unknown error
  • Adobe Media Encoder – Unknown error
    Posted by Philip Merten on August 16, 2012 at 2:45 am
    Greetings:
    I have a DVCPRO HD 1080i sequence. I’m using Premiere Pro CS6. I tried exporting it to h.264 for Youtube using the 720p preset and after a few minutes it stops rendering and “Unknown Error” pops up. I tried different settings (AVI, MOV, etc..) and got the same results. In other projects the AME works fine. If anyone has any suggestions on how to fix this I would greatly appreciate it..
    Philip
    Ethan Gallo replied 13 years, 10 months ago 4 Members · 5 Replies
  • Dennis Radeke
    August 16, 2012 at 12:02 pm
    Try cleaning out your media cache. Alternately, try trashing your prefs on Premiere Pro and finally, open up another project and see if you’re having the problem with all projects or just the one.
  • Douglas Morse
    August 17, 2012 at 2:48 am
    I had to reinstall OS and Adobe Suite to get rid of my errors. I wrote up a short blog post https://thefilmprofessor.wordpress.com/2012/08/14/editing-woes-and-solutions/
  • Philip Merten
    August 17, 2012 at 3:17 pm
    Thanks Dennis, that was very helpful in solving the issue..
  • Ethan Gallo
    November 14, 2012 at 1:25 pm
    Hey, I recently ran into a similar problem. Apparently there is a glitch when you queue a sequence in media encoder that contains .mkv files (from AVCHD cards or archives) When working with them in premiere initially I got a status bar at the bottom that said “conforming 00000.mkv” which is some sort of pre rendering it does to interpret the footage without having to transcode it. Apparently when you send it out to AME it has to re-conform the footage, but I didn’t notice the status bar in the bottom of the “select a premiere pro sequence” window. After letting that window sit and do its conforming of the clips again, I hit okay to send the sequence into the queue. The sequence is currently outputting normally without errors (it’s really long) and I had been getting the same thing where it would go for a minute or so then come up with an unknown error.
    SO long story short, if you’re working with some form of card based footage (not necessarily AVCHD, could be EXCAM or something else too) straight into PrPro without transcoding, try opening the project via Dynamic Link in Media Encoder and once you navigate to the sequence, but BEFORE you add it to the queue, see if there are any progress bars in the bottom right corner of the window that need to do some thinking before you start the encode.
    Hope this helps
    Ethan Gallo-
  • Ethan Gallo
    November 15, 2012 at 12:20 pm
    oops, typo. AVCHD archives use .MTS files not .MKV, other than that, it did fix the problem for me. The file outputted.
    Ethan Gallo-
