Activity Forums Adobe Premiere Pro Adobe Media Encoder Problem
  • Adobe Media Encoder Problem
    Posted by James Johnson on May 26, 2010 at 6:45 pm
    Hi all,
    I am trying to export my 30 min video from Premiere Pro CS4 with AME. When it starts off, it estimates around a 30 min queue. However, as soon as it get halfway through, everything comes to a crawl and the estimated time continues to rise (i waited long enough for it to go up to 4 hours, and you could barley tell the loading bar moved) WHAT IS THAT CRAP!? I am exporting as wmv, other settings are same as sorce. anyone got any ideas?
    Sylvia Porter replied 16 years, 3 months ago 2 Members · 1 Reply
  • Sylvia Porter
    May 29, 2010 at 10:50 am
    I can certainly understand the frustration. That crap is probably encoding to WMV. It’s a fine format, but it (in my experience can sometimes require a lot of processing time, because there’s a lot of compression happening). The times given for a render are based on the location progress of the rendering engine. So if in the beginning you have clips with little or no effects, the estimate is given based on that. If the render gets to a place where you have a “crap” load of effects, etc., the estimate is given based on that and the render will also bog down and seem like it’s not moving.
    Here’s a trick. I love wmv, so I’ve done this a lot with bigger projects. Exporting to other formats can be much faster. So I will find the fastest export to another format and then render that to wmv. This gives me a full quality version of my project and it usually renders faster when the renderer is just processing images and not effects and cut and whatnot.
    The other format should be lossless…meaning no compression.
    A lossless format would be one that doesn’t allow setting compression and keyframe distances, etc.
    Another thing if you’re using CS5 the good news is that you can check ‘use previews’ in the export settings and this can help to save some time.
